Buying Kreem?
Hi all-
Where can I find this stuff? I've looked all over town with no success. I've got gas leaking into my oil pump and oil leaking into my carb...need to seal holes..
help!
Re: Buying Kreem?
Bruce Wilkinson /
Phone the motorcycle shops and dealers.Be sure to follow the directions for good results.
Re: Buying Kreem?
local motorcycle shop or airplane repair shop. thanks Ray
Re: Buying Kreem?
Curtis Onstott /
I like POR-15 gas tank sealer. It will not dissolve from gasoline additives. I've used it several times.
Re: Buying Kreem?
POR-15 rocks!!
Just say NO to kreem!
I've used both, no comparison.
Peace
Spence
Re: Buying Kreem?
Kreem SUCKS lol
Re: Buying Kreem?
Allen Murphy /
I've got a Honda with a gas tank that someone used Kreem on.
I've cleand the carbs WAY TOO often to get the KRAP out of them--so much for using Kream on anything other than a toilet tank!!!
Al Murphy
Re: Buying Kreem?
Bruce Wilkinson /
I have a feeling that the instructions were ignored if you are having a problem with a Kreemed tank. I have done two with no problems at all and would do another if I had to.
Re: Buying Kreem?
NAPA sells it
Re: Buying Kreem?
Thanks everyone- I sealed both my oil and gas tanks and it coated nicely, even sealed a very large hole that I was sure would still leak. It worked out fine since my paint was faded and splotchy to begin with but I wouldn't use it on a nice shiny gas tank, seems nearly impossible to prevent any spillage.
Donna
Re: Buying Kreem?
Good luck with it,and I hope it doesn't start peeling off.You don't know what trouble is until that happens.Jerry.
