leaking tranny fluid
Hey all, I am leaking tranmission fluid out of where the cluch cable goes into my sachs 505/1. How hard is it to replace this cable? also, can you use a high temp. sealant around this area to stop the leak? Thanks
Re: leaking tranny fluid
This might seem obvious, but are you sure the transmission is not overfilled?
absolutely positive. I've drained it way past where it nees to be, filled it up, an let the cap sit off for at least an hour so it could drain out the hole, just like my manuel says. I've overfilled it, and underfilled it with the same results. It just seems to leak right around the housing for the cable where it enters the engine. Thanks though. Any more sugguestions?
