My point isn't moving
I have a 1978 Puch Maxi, I bought it from a friend for 10 bucks, it hasn't ran in about 10 years. I looked at the flywheel today and turned it to see of the points opened. I have never owned a moped and am trying to refurb this one. Any ideas on why it isn't opening. None of the wiring is hooked up but i don't think this would matter.
Re: My point isn't moving
Jason Luther /
are they rusted together? does the flywheel turn?
Yes the flywheel turns and i can force them easily apart with a screw driver, Thats why i don't know what up
Leon Swarmer /
The points are held down by an adjusting screw. You need to loosen it, and physically move the point set till they rub against the cam a little bit. Then when you turn the flywheel slowly the cam should open the points.
Have you looked for a manual at the MRA?
And no, it doesn't matter for this question if any wires are on it or not.
Leon
Alrighty I will try that thanks.
