Transmission leak
I have a 1980 Sachs Suburban. I am new to mopeds so bear with me. It seems to be leaking transmission fluid (pinkish fluid) at the clutch decompressor on the cylinder. There seems to be no gasket on the decompressor according to the manual. Do you think I need a new decompressor? Also what type and how much transmission fluid do I need to use for the moped? Thanks for the help.
Re: Transmission leak
Also the leak seems to be right at where the two cables meet. The cable coming from the hand clutch and the one coming from the engine case
Help would be appreciated. Thanks
Would Klotz Flex Drive 30 2-stroke transmission lube work if I needed to add anything to the gear box?
