Very smokey
I just chanfed the tranny fluid on my 2001 TTLx, and the next morning the bike was VERY smokey out of the exhaust. It covered of half of the road. Would this have anything to do with the oil change? I have had the gas in ine moped mixed with oil since Friday. I pre-mix. It just started today. Thanks!
Re: Very smokey
Either you overfilled the transmission or you did an incorrect gas/oil mix.
Re: Very smokey
sometimes if the tank isn't shaken fully, either too much oil or too much gas may be let through by the petcok if its not fully mixed. Maybe you had a lot of oil in the mixture? As long as you filled it on a level surface and let the excess out of the overfill part, there shouldn't be any reason for the tranny fluid to cause exhaust to smoke.
Re: Very smokey
Sean, I know that the tank was shaken correctly.
Re: Very smokey
kk.
