Re: Cylinder stud stuck to head
Xxxxx Xxxxx /
Whatever you do,be very careful.You will either break the stud,or break a chunk out of the head.You can try heat(from a heat gun,not a torch),penetrating oil,see if you can get some Kroil.You can tap on it with a piece of wood,or a rubber mallet.Get some of those wood shims for door jambs and cabinets,and try driving them between the head and cylinder.Have patience,it will eventually break loose.Be especially carefull if the parts envolved are something that would be difficult or impossible to replace.Jerry.
