removing puch pedal assembly
Matthew Libhart /
All,
I'd like to remove the whole pedal assembly on a '78 Puch. Can I simply remove the axle/sprocket (right) side once the left side crank is off or are there bearing rings or other parts hiding inside the body that will get lost in there if I do this?
Thanks again.
Re: removing puch pedal assembly
take the pedal arm off on one side and the axel just slides right out.. there is nothing holding it in:P
yep
just remove one pedal and the whole thing slides out really easy
there should be a small bolt at the betal where the pedal axle is
just remove that bolt and tap out the pin
betal? darn, still no edit post button
I hate when that happens lol
yea
i was reading it as it was lading and almost cought it but i was not fast enough
