2 speed to 1 speed switch?
hi i have an 80 Maxisport MKII with a 2 speed and was wondering if i dould put a 1 speed on it?
will it bolt up???
Re: 2 speed to 1 speed switch?
yes, same bolt pattern
Some items get a bit cramped, though...air filter did on mine, exhaust was a little tight too.
ok thanks
I have a 1-speed on mine, and I have no issues with cramping. I used the stock magnum airbox (I know) and mag hi-torque head (I think). The only thing that was strange is the exhaust port is different so it hangs lower coming from the header. You can just fabricate a clamp for the rear. If I have a moment, I'll take a pic and post it later. No other problems though. You lose a noticable amount in initial acceleration, but I don't mind. Make sure you get the 2hp 1-speed engine to help, and the hi-torque head will assist too for power.
ok i also have a magnum airbox and i hav a 2hp cylinder on the 2 speedbut the 1 speed has a blown top end so i was gunna kit it out
