Re: Rusted gas tank
Roman /
Try small nails, they are sharp, and will scratch the surface better, then you can use "Rust-off" primer (phosphoric acid), that I bought in "Advance Auto Parts" for $4.95.
And after the acid, I used JB weld epoxy, because my tank had pin holes right near petcock pipe entry. I could see them from the filler opening, and delivered the epoxy by wooden stick, and spread it there. So my fix was around $9 total… and it holds so far.
  Rusted gas tankTopic by: Bill Johnson Bill Johnson 10/06/05 07:57AM
  Re: Rusted gas tankRe: Roman Roman 10/06/05 11:00AM
  Re: Rusted gas tankRe: Mike Mike 10/06/05 11:31AM
