Turn signal question (newb question)
Hey. I just want to know if this is normal or not: my turn signals don't work at idle. I would think its rather important that they do, because when at a stop sign people should know what i'm doing. BTW 2005 Tomos ST
Re: Turn signal question (newb question)
Adding a regulator and a battery should solve that.
I don't suppose there's a write-up on that anywhere that you know of?
idk about a streetmate, but on my LX i had to replace the flasher .. or jus rev it up wen u stop
Not a streetmate, the Targa ST... so its the same as yours, except you have a top tank (or so I think... remember, noob here). Did you have the same problem before you replaced the flasher?
yes, had the same problem and i replaced the flasher and it works great now
