My batavus is dead (almost)NEED HELP
By this point i am VERY VERY frustrated w/ my 78 batavus starflite. I have done everything i can think of to get it running correctly: clened the points, new spark plug, cleaned the muffler, took apart the carbuerator completely apart and clened that w/ carb cleaner, and basically thats it. BUT.....the thing still runs like SHITE (topping out at like 10mph) i really dont know whats wrong with this at all. Any help is greatly appreciated!!!
JAKE
Re: My batavus is dead (almost)NEED HELP
Try running it without the airbox and/or the muffler, see if that makes it faster. Maybe change the timing. Remove any carbon buildup on the cylinder head or piston. Thats all I can think of.
Ya , i did take the airbox off, and the muffler but to no success......how do u change the timing>???
use flywheel puller to remove magneto
unscrew (not all the way!!!) the three stator plate screws
there will be a marking or some sort of notch between the stator plate and the engine
use the notch as a guideline and rotate the stator plate left or right, left retards timing and right advances
*rotate in increments of 0.03"
I did this and it still wont run rite- now topping at 15 mph!!!! I also looked at the clutch but i couldnt see ne thing wrong-pleeeeeeeeeeez help me!!
jake
how big is the gap when your points open
not very big-prolly cereal box size
