Re: my PA50 freakin broke again!!
Silverfox Sullivan /
That's what it sounds like to me. Someone fooled ith it while you were inside.
In normal starting mode the pedals drive the chain on the right side, the chain drives the rear wheel, the rear wheel drives the belt, the belt turns the variator, and the starting clutch drives the engine.
If you crank the pedals and nothing happens, either the rear gearbox is not engaged or the v-belt is so loose that it will not drive the variator.
