Sachs G trouble
Hey!
I just bought a very nice Sachs G3. The ped was sitting since ’86 because of a wipe out. Basically the front brake perch was broken and the owner didn’t feel safe riding it anymore.
Anyway I pulled the carb and cleaned it up. And put fresh fuel in the tank. The tank was very clean. The Ped started right up and ran great. I guess after a few min I realized I didn’t check the gear case oil. Sure enough there was no oil.
I filled the gear case and the ran the ped again .Now it boggs and wants to stall at full throttle. I pulled the carb again and it was perfectly clean. Pulling in the choke will allow the engine to rev up.
Arggg. Dose anybody have a clue.. Perhaps the crank seals? .. The thing is, the engine doesn’t seem to be pulling in extra oil from the gear box. That would be typical of a bad seal.
Any ideas?
Re: Sachs G trouble
Check the main jet. See if its clear
Re: Sachs G trouble
Hi,
When I pulled the carb the second time, I took the main jet off and was able to see through the little hole. I also checked the tube that the main jet screws on to. The tube was clear and the holes at the end were clear.
Re: Sachs G trouble
check your idle screw
