Re: Removing Piston Pin Difficult?
spartadude /
Other option:
Do you know the screwdrivers with the option of putting different heads/tops inside? Their shaft has the diameter of most types of piston-pins, i normally use this tool and slowly increase the pressure used. If its tight heat it with hot air and then apply some WD40.
Don't use a normal screwdriver the risk of damaging the piston is to high, just a small incision on the side of the hole of the pin means a higher risk of the piston damaging your cilinder, goor luck, Maarten
