Re: Removing Piston Pin Difficult?
Brett Walker /
anything thats the size of the inner diameter of the hole will work
i usually use a 6 in 1 screwdriver, if you take the bit out it fits perfectly inside the writs pin hole, you can also use the appropriate sized socket
