Honda PA%) Fuel Problem
Josh Hunt /
Hi,
I,m unable to find the low speed fuel circuit in the carb.
The motor runs fine as long as I keep the revs up. I can't get it to idle, and to keep it running I have to blip it &/or put on the choke.
I've pulled the carb out and cleaned and blown out the main jet & emulsier jet etc. - etc., BUT it still won't idle, so I figure the low speed ciruit is clogged, but I can't find it - YES, I have removed & cleaned the fuel/air adjuster. Is there a channel in the carb that runs from above the main jet area to the fuel/air adjuster that is hard to see??
Thanks
Josh
