puch bing's. any way to adjust mixture?
wondering if you can adjust the fuel/air ratio?
and what is the point of the screw on the side?
Re: puch bing's. any way to adjust mixture?
That screw on the side adjust the mixture at idle only.
You can adjust your midrange mixture by moving the needle up and down using the clip inside the carb slide.
To adjust full throttle mixture you will need to buy some main jets.
