choke problem....
My freind has a problem with his choke. He has a 1999 tomos lx and when he presses the choke down and starts it it wont come back up on its own. does anybudy know why this is?
thanks joe
Re: choke problem....
Tighten the slack in the throttle cable.
Grey
Live to ride, Ride to work
Jason Luther /
loose throttle cable
Jason Luther /
jinks
thanks all tell him that but i have an old 1991 tomos that doesent run and the choke wont go to off. Do i need to losen the throtel cabel on that or what?
thanks joe
if your having the same problem you would need to tighten the throttle cable also. Duhh. Anyways, sometimes if the throttle cable was replaced they put the black part on backwards, it happened to me once, or the choke mechanism is broken.
how do you tighten the cable?
