MBK gets going...sputters..keeps going
So my MBK 50v gets going just fine....but then it starts sputtering...like it isn't getting enough gas..but there is plenty of gas in the tank and in the fuel line etc...This happens uphill, straightaway, downhill. Happened just now in a parking lot. Any thoughts?
--NB
Re: MBK gets going...sputters..keeps going
John Joedicke /
Clean the carb and check your jet for partial blockage. Put a filter on line.
filter is there....carb is clean...jet is clean....
do you have good gas flow from the tank? Does the air vent hole in your gas cap work? I've seen that cause this problem pretty often.
hmmm how to check if air vent hole works?
I see a hole on top of the tank cover, and on the inside....seems like nothing is blocking the air passage....there is gas in the fuel line...thoughts?
moron me was .....wait for it....OUT OF GAS
John Joedicke /
Might be a problem for a lot of people down there soon!
Edward Helbling /
Nice work. I was going to suggest checking the plug......but I think your solution will work better.
