minarelli V-1 gear oil?
I used non-detergent SAE 30w oil in my V-1 gearcase. iS THIS THE RIGHT STUFF? someone told me to use automatic transmission fluid. The stuff that came out used to be oil. It runs great and does just about 30 on a flat road. SOund right to anyone
Re: minarelli V-1 gear oil?
Non-detergent is the correct stuff. My manual says to use 20W30. If it gets real cold where you live and you ride in the winter, changing it might be a good idea otherwise the 30weight you put in should be fine.
awesome...thanks
