Re: Puch Maxi Starting Troubles
jim /
well, it had been a gradual loss in power over the summer, you know where full throttle kills the engine and it immediately hit me as a carb problem...
it had gotten to the point where it did not start at all and when i tried to start it after cleaning it felt much cleaner and stronger...but not willing to pick up and go
the results from spraying fuel directly into the head were promising, it ran like a champ for 50ft so im reluctant to cite any compression/exhaust leaks...but ill see for an exhaust leak all the same because god damn, gas is 3.30/gal in Ct and i just need to get around hartford in the most awesome way possible...
