Re: Puch Maxi Starting Troubles
Daniel Van Donsel /
There is only 1 jet in the carb
Unscrew the bowl and you will see it.... in the middle... its a timy brass screw with a hole in the center under the float...
Get a can of carb cleaner with a pipette attached and blast it out... you may need to run a fine strand of wire through it as well...
This should solve your problem.... if its the jet :)
