Re: Tomos Moped Clutch Problems
Thanks for the advice. With regards to the transmission fluid, I just recently changed it with Type F. Is it possible that I didn't put enough in? Or perhaps it needs more? I know that you're suppose to fill it up to the screw. I actually had some fluid still trickling out of the hole when I put the screw back in. Should I take the screw out, and make sure that the fluid level is definitely below the screw.
Bob
