dial gauge ?
Troy Brown /
after finding TDC,now what. does one revolution= 1mm?What the little dial for, and next to the little dial is0.01mm.
Re: dial gauge ?
HTH.This was for a puch using an english measurement gauge.Jim https://www.mopedarmy.com/forums/discuss/read.php?f=1&i=202066&t=188637
Re: dial gauge ?
The little dial tells you how many times the large dial has gone around 360 degrees.The small dial is probably graduated 0 to 9. just remember the metric system is graduated in tens.ten MM is one centimeter and each mm is also brocken down into tens and so on.Hth.Jim
