Puch Magnum XK Engine
Does anyone know if the crankshaft in the engine on my 1978 Puch Magnum XK has a sleeve-type bearing or needle-type bearing?
Obviously, I could simply tear it down and find out, but I'd rather avoid the hassle.
TIA.
--Tom
Re: Puch Magnum XK Engine
im pretty sure they all have sleeve bearings, and the korado motors from a few years ago are the only ones with needle bearings.
Round sleeve type :P
Ok take out my trusty 8/79 manum parts book.The one speed XKs use for a crank bearing right side Deep row ball bearing 40/17/12 6203 ZNR Puch part# 900.6233 that's the bearing with the snap ring around it's circumfrence to locate the bearing in the case.The left side uses Deep row ball bearing 40/17/12 6203 DIN 625 puch part# 900.6203.As for the connecting rod wrist bearing that's a sleve/Bushing Puch part# 349.1.10.021.3 Hth.Jim
