Re: Motobecane will not run w/out choke
Dan Adams (50:1) /
It sounds to me like fuel blockage, or an airleak.
The way the crab mounts to the intake is a little wonky sometimes. Do you have a plastic mounting gasket where the carb mounts? (some models do) Is it messed up?
Are you sure the carb is pushed all the way on the intake?
It does not sound like timing to me.
How is your compression?
