choke cable routing on my 103?
I'm putting together my '77 peugeot 103 that I got minus a carb. Now that I have one (stock Gurtner) I can't figure out how to run the choke cable without a real tight radius. As far as I can tell the cable starts out on the left side of the tank and then needs to run to the right side of the carb where it threads through a hole just below the plastic cap. Tha cable then drags across a screw head and terminates at the lever. In order to get the cable to mount to the carb it has to turn a tight 90 degrees and this causes the cable to drag and the choke doesn't sping back open. Are there any pictures anywhere that detail the choke cable routing? Thanks
-todd
