I never had a setup like that, but I did build a bracket that attached to the left rear, beside the wheel, that held a one gallon plastic oil jug, which I carried premix in. I had to drill a couple of holes in the left fender strut to install it. Then I installed nylon bicycle panniers on the rack, one on each side (basically saddlebags) and carried extra fuel in those. I removed the bracket, and replaced the fender strut that I drilled holes in.
