Re: Serious problem with Solex
Brian Solex /
Bill,
You are supposed to change the whole assembly, that is the drum/roller assembly. If you look at the MBK S 3800 parts catalogue, on the galet-embrayage page (roller-clutch), http://solexin.free.fr/medias/acrobat/sws_doc_solex_3800.pdf ,the individual pieces aren't even listed, just the whole assembly, 61287, rep. 1 in the diagram.
To change just the roller is not the easiest job, and you need an eight-point, thin-wall 37mm socket to loosen the drum nut. (see attached photo)
I don't know the projected life, but I've never had to replace one. If you use incorrect tires, you will wear it away. I've read about one that cracked into a few different pieces and was glued back together and had some carborundum grit glued to it.http://www.users.globalnet.co.uk/~pattle/nacc/arc0108.htm
So, I recommend swapping the whole drum/roller assembly. It will be very easy to do.
  Serious problem with SolexTopic by: Xxxxx Xxxxx Xxxxx Xxxxx 09/07/05 05:24PM
  Re: Serious problem with SolexRe: Brian Solex Brian Solex 09/07/05 07:07PM
  Re: Serious problem with SolexRe: Xxxxx Xxxxx Xxxxx Xxxxx 09/07/05 08:08PM
  Re: Serious problem with SolexRe: Xxxxx Xxxxx Xxxxx Xxxxx 09/07/05 09:53PM
  Re: Serious problem with SolexRe: Brian Solex Brian Solex 09/07/05 11:42PM
  Re: Serious problem with SolexRe: Xxxxx Xxxxx Xxxxx Xxxxx 09/08/05 12:34AM
  Re: Serious problem with SolexRe: Brian Solex Brian Solex 09/08/05 08:32AM
  Re: Serious problem with SolexRe: karl karl 09/21/05 02:28PM
  Re: Serious problem with SolexRe: Nicholas Nicholas 09/26/05 06:59PM
  Re: Serious problem with SolexRe: Brian Solex Brian Solex 09/27/05 02:13AM
  Re: Serious problem with SolexRe: Nicholas Nicholas 09/27/05 06:36AM
  Re: Serious problem with SolexRe: Xxxxx Xxxxx Xxxxx Xxxxx 09/28/05 03:06AM
  Re: Serious problem with SolexRe: Brian Solex Brian Solex 09/28/05 08:52AM
  Re: Serious problem with SolexRe: Legendre Legendre 09/07/05 07:31PM
  Re: Serious problem with SolexRe: Xxxxx Xxxxx Xxxxx Xxxxx 09/07/05 07:59PM
  Re: Serious problem with SolexRe: Jeff Matthews - VeloCruz Jeff Matthews - VeloCruz 09/07/05 09:37PM
  Re: Serious problem with SolexRe: Xxxxx Xxxxx Xxxxx Xxxxx 09/20/05 10:13PM
  Re: Serious problem with SolexRe: Xxxxx Xxxxx Xxxxx Xxxxx 09/08/05 11:46PM
  Re: Serious problem with SolexRe: Legendre Legendre 09/21/05 11:24AM
  Re: Serious problem with SolexRe: Legendre Legendre 09/28/05 10:06AM
  Re: Serious problem with SolexRe: Brian Solex Brian Solex 09/28/05 10:55PM
