Re: Serious problem with Solex
Xxxxx Xxxxx /
Thanks Brian.Also just to let you know,the fuel leak is back again.It is not the fuel line connection,there is actually a crack in the tank at one of the screws that holds the metal V shaped mounting bracket to the tank.If you're looking at the tank right side up from the back side,it's at the lowest screw on the upper right.Thats what made it so hard to track down.It wouldn't leak if the fuel level in tank was below that point.By the way,despite my earlier post,I really do like this bike,and hope it can be properly repaired.This morning,before the wheel fell apart,I was really enjoying myself,like I hadn't in a long time,just cruising down the road through farmland.There is something relaxing about the Solex that other mopeds just don't have.Jerry.
  Serious problem with SolexTopic by: Xxxxx Xxxxx Xxxxx Xxxxx 09/07/05 05:24PM
  Re: Serious problem with SolexRe: Brian Solex Brian Solex 09/07/05 07:07PM
  Re: Serious problem with SolexRe: Xxxxx Xxxxx Xxxxx Xxxxx 09/07/05 08:08PM
  Re: Serious problem with SolexRe: Xxxxx Xxxxx Xxxxx Xxxxx 09/07/05 09:53PM
  Re: Serious problem with SolexRe: Brian Solex Brian Solex 09/07/05 11:42PM
  Re: Serious problem with SolexRe: Xxxxx Xxxxx Xxxxx Xxxxx 09/08/05 12:34AM
  Re: Serious problem with SolexRe: Brian Solex Brian Solex 09/08/05 08:32AM
  Re: Serious problem with SolexRe: karl karl 09/21/05 02:28PM
  Re: Serious problem with SolexRe: Nicholas Nicholas 09/26/05 06:59PM
  Re: Serious problem with SolexRe: Brian Solex Brian Solex 09/27/05 02:13AM
  Re: Serious problem with SolexRe: Nicholas Nicholas 09/27/05 06:36AM
  Re: Serious problem with SolexRe: Xxxxx Xxxxx Xxxxx Xxxxx 09/28/05 03:06AM
  Re: Serious problem with SolexRe: Brian Solex Brian Solex 09/28/05 08:52AM
  Re: Serious problem with SolexRe: Legendre Legendre 09/07/05 07:31PM
  Re: Serious problem with SolexRe: Xxxxx Xxxxx Xxxxx Xxxxx 09/07/05 07:59PM
  Re: Serious problem with SolexRe: Jeff Matthews - VeloCruz Jeff Matthews - VeloCruz 09/07/05 09:37PM
  Re: Serious problem with SolexRe: Xxxxx Xxxxx Xxxxx Xxxxx 09/20/05 10:13PM
  Re: Serious problem with SolexRe: Xxxxx Xxxxx Xxxxx Xxxxx 09/08/05 11:46PM
  Re: Serious problem with SolexRe: Legendre Legendre 09/21/05 11:24AM
  Re: Serious problem with SolexRe: Legendre Legendre 09/28/05 10:06AM
  Re: Serious problem with SolexRe: Brian Solex Brian Solex 09/28/05 10:55PM
