Re: It wants to run so bad...
Legendre /
Use a compression tester. Attach the tester, turn off the choke and hold the throttle wide open. Pedal hard like you are trying to start it, until the gauge on the tester peaks out. Take a reading, and try the test a couple more times until you get an average.
