Puch Maxi throttle cable
Nicolas Anbeek /
I busted the throttle cable on my 1975 Puch Maxi. I'm wondering if I have to replace it, or will a bicycle brake cable work? Anybody have a spare throttle cable?
Thanks very much!
Re: Puch Maxi throttle cable
does your throttle use the cable with the bead on the end or is it a screw type?
Nicolas Anbeek /
It uses the bead on the end.
That style is problematic because the cable end pops out...
You can replace it with the screw-in type by popping out the pin that holds it in place and switch it for a tiny piece with the screw style..
You can buy the cable for like 12 bucks at handybikes with the little piece included to make the switch!
Nicolas Anbeek /
cool, thanks for the info
Jason Luther /
also do a search, people have had all sorts of cleaver fixes for throttle cables? where did it break?
