Re: moped wont start!!
john /
If you have 0 or close to 0 exhaust flow it will not start ,trust me.
on a 4 stroke
the piston goes down drawing in the fuel and air
then the piston comes up compressing the mixture
and then pow you have spark{at the right time} on the power stroke as the piston goes down
and then the piston comes up forcing out the spent gases out the exhaust.
on a 2 smoke it does it in only 2 strokes but just the same
If you do not have all 4 it will not run or start period. You could almost stretch it a little and say 5 , ignition timing, but that falls in the power stroke.
Are you still there mike? does it have spark
Don O is right on about the tail light issue.
