What kind of oil?
Hi, I'm a new member from Bulgaria and I'm a owner of Simson suhl SR2. It was to my grandfather but he give it to me to use it. I like the moped very much but I have some problems with it. If someone can help me I'll be very thankful. So the problem is that now I disjoint all parts, because I want to repaint it and i hear a strange noise from the clutch and the moped is loosing power - it is difficult to climb a little hight on 1 gear and strange metallic noise is hearing from the engine - like a noise from a spring. The other question is what kind of oil for transmission and the section of the clutch to use - is it the same or not?
Re: What kind of oil?
Hey man!
That's a COOL moped!
Welcome !
John Joedicke /
Is it an automatic or a manual shift transmission?
it's with manual transmission
by the way someone does have some manual about that model? I found documents in german but i dont understand the language
John Joedicke /
Probably will use gear oil like the old Casals and Zundapps. SAE 80/90
for both section of the clutch and transsmition?
I doubt that your East German made Simpson was ever imported into the USA. Your best bet is to get someone to translate the German manual for you.
Good Luck.
