I have a one speed 1977 puch maxi.
In order to start, the starter cable (clutch) has to be pulled to its maximum tightness for the clutch to "grab" the declutching lever must be pulled very hard. I have already swapped the clutch hub with a spare used clutch hub, they both appeared to have clutch pad life left.
Right now it too hard to start with lever (hurts hand) so I resort to using vice grips to pull the cable up ( if you can picture that) Anyways, is there another part that could be worn or needs adjustment. possibly the declutching shaft?
Right now I will take any suggestions because I can't think of anything!!
Thanks,
Chris
