Moped dies when i give it gas
My Peugeot 103 moped has trouble starting. When i give it gas it gives a little putting noise and then chokes. Riding down hills gets the engine turning over and going but once i get to flat ground or continue pedaling as hard as i can it dies.
Re: Moped dies when i give it gas
Jason Luther /
when you 'give it gas' you are actually giving it air. i bet your main jet is plugged our you have other fuel delivery issues. first see if fuel is flowing unrestricted to the carb, and if so, clean the carb.
Steve Meyers /
Try turning the choke off
new moped boy /
ok so i cleaned the carb checked the choke and found out after words that the timing was off!! i was discouraged. thatnks for ur help guys
