tomos engine question need help!
Troy Weisenmiller /
ok so i jsut got a 95 tomos sprint, i cna hear air coming out of this hole on the right hand side of the engine.
it looks like it can be a vent thing? but also the other side has a screw in it, i attached a pic to show the hole.
speed is still good, at around 30mph, 35 on tomos speedo.
do i need ot find a screw for this and am i hurtin anything with it not there??
please help
Troy
Re: tomos engine question need help!
John Joedicke /
Isn't that just an alignment dowel pin for the casing. What air can come out of that? Maybe you either have a leak at the reed valve manifold or the bottom gasket. Torque the head (10 #) and retighten the reed down and use blue locktite.
Troy Weisenmiller /
ok i just got around to clean the bike up,
it does look like it supposed to be there, and i dont think air is comin out of it, maybe i was jsut seeing things?
but ill tighten down all screws i see, and i got locktite on hand!
thanks
John Joedicke /
Blue loctite!
Troy Weisenmiller /
i got both, but ill use blue
what the diffenrcence
Troy Weisenmiller /
blue lets you undo the screws iuf they need to be taken out again, red is like welding them there and very hard to get taken back out. i think?
Correct.
