tomos repair general questions
2005 ttlx limited edition... where is the transmission fluid and how do i replace it? How do i remove the airbox and then what do i do with it from that point: jet? filter? and how do i do it.
Re: tomos repair general questions
To change the transmisson fluid, remove the drain plug,once the fluid has drained, reinstall the plug. Now remove, the filler bolt (you will have to remove the right side cover and airbox and remove the fill screw. Fill till the atf comes out the level screw. Use ATF Type-A.
Grey
Live to ride, Ride to work
