Long life and restoration of Small Engines - XADO
WM-e-Shop.com /
XADO technology http://www.xado.com
Revitalizant gel for small engines
Revitalizant gel for small engines Major results of the treatment Extension of engine life by no less then 3 times; Restoration of cylinders, elimination of scores; Increasing of compression in... More>>>
http://www.wm-e-shop.com/product_info.php/cPath/1_3/products_id/96
OR
Revitalizant gel for cylinders
Revitalizant gel for cylinders(product is certified) Major results of the treatment increased compression in the cylinder; restored geometry of the cylinder, elimination of scores; protection of... More>>>
http://www.wm-e-shop.com/product_info.php/cPath/1_3/products_id/4
All line of production XADO
Re: Long life and restoration of Small Engines - X
John Joedicke /
Looks like spam here
Steamboat Aka J. R. Stevens /
Snake oil. Jim.
Don Pflueger /
miracle cure in a bottle. lol
Jason Luther /
no way this! this stuff fills in and rehones worn cylinders! this will revolutionize mopeding as we know it! send me a case on donp's tab
The only gel I use is KY. Works great for my engine.
Don Pflueger /
yea i threw away all my tools since i will no longer need them as all i gotta do is pour this elixir in my gas and go. engine rebuilds as i ride.
Cyborg Elko /
elko OP
New site of XADO Online Store
http://www.xado.wmeshop.com/
XADO gel for cylinders
http://www.xado.wmeshop.com/XADO-gel-Revitalizant-for-Cylinders
After XADO revitalization the cylinder geometry restores, the inner diameter reduces, ellipse deformation of cylinders disappears preventing expensive overhaul. As a result a renovated unit by its running quality will exceed the performance level and will serve you from 2 up to 4 times longer.
The following results were received:
Increases compression;
Removes holes and scratches up to 0,0003 inch;
Protects cylinders from wear-out during “cold” start;
Reduces noise and vibration level;
Increases engine power;
Reduces fuel consumption;
Allows to process one or couple cylinders. (edited)
Re: Long life and restoration of Small Engines - XADO
I just got a warning from Kaspersky antivirus not to open this site which contains a malicious bug. don-ohio (:^/
.0003 inches is half the thickness of a cigarette cellophane. So basically not enough to matter. This stuff sounds dumb.
