Re: Puch won't start possible wiring problem
harold /
on the new switch (if it matches the orignal) the 2 black wired would connect to the outer posts and the brown goes to the center......the switch lever may rotate on the center post......that is how my maxi is wired ....i looked at it before replying ..........if that doesn't work make sure the wires are tight on the coil and the plug is clean.....if all of the wires are tight it should fire......puchs are very simple to figure out
