Honda MB5 piston Bore Clearance
Hello,
I have a 1982 Honda MB5, I about to rebuild the top end, but I don't have the piston to bore clearance spec. Does anyone know off the top of their head or have a workshop manual?
Any help would be great,
Thanks
Re: Honda MB5 piston Bore Clearance
the standard is .030 mm to .060 mm from piston to bore the service limit is 1.00 mm either in or out
personally if it is not within the standard i would rebore or replace jug and piston
Thank you very much
Jason Luther /
do you mean the max is .1mm?
