Re: 2002 Tomos Targa Choke Stuck On
Danny Moped /
Spray everything down with WD-40. Make sure your cable has a little oil on it, the slide in the throttle should also be oiled. It also wont hurt to crack open the top of the throttle and spray a bit in there. Then, click the choke on and pull the throttle a bunch. This may give you enough to make it release right away.
Go nuts.
DannyMoped07
