Re: 2002 Tomos Targa Choke Stuck On
John Joedicke /
Just loosen the 2 screws on the top of the carb. Don't take it off, it should click back. You need to take up the slack in the cable by the hand grip. Look under the grip and there is a small set screw. It is probably loose. Use needle nose pliers to pull the cable taut and then tighten up the set screw.
