MOPED Won't IDLE
Capt. Walter J. Spinelli /
I HAVE A 1978 PUCH CARB1/12/304 I installed a new Float needle , and a new Float bowl gasket ,
I can,t make it idle without stalling . The idle mixture screw does nothing when I turn it in or out. I adjusted the cable but still no luck. Any advice on what to try to get my PUCH to IDLE?
THANK YOU,
Capt, Walter
Re: MOPED Won't IDLE
is there a partial opening in the carb to let air in?. if not tighten the throttle cable
make sure the choke lever, pulls the choke slide up and down. the choke slide can fall off the choke lever and its very easy to over look when putting the carb back together. your bike wont idle if the choke is always closed.
good luck
-backwards
