Re: PA 50 II jet
Joe Woods /
not owning a PA50I. im not sure.. silverfoxhas the microfiches, but part numbers could be different for identical parts... but the jets have a ID number stamped on the screwdriver-slot ends..
i get the impression the rear wheel gear boxes have the same 12.4:1 ratio but variator ratios are certainly different.. And the carbs are different afaik, the PA50II having the 11.5mm Keihin where the PA50I has a 10mm. Someday i'll come across a PA50I and make a list.
