Re: carb leaking gas
j potato /
step 1 go to honda dealer step to tell him what u need(gasket kit)
step 2 had him 10 dolar bill
step 3 get change(mine was $5.87)
step 4 take apart carb clean real well
step 5 reasemble with the proper orings
doing other than this(using gasket material using gasket sealer rubberbands(yes ive seen it) these will fail because of how things fit oh and ps the oring set i got had an extra oring in it i found out later that the same kit is for like 10 other carbs so dont let this allert you when u r sitting there with an extra oring
