Re: i need help... cant keep it on!~
Joe Woods /
_gas flow is fine i think_
if you measure how much fuel is in the float bowl you'll see it's not very much.. maybe 20 or 25ml .. unless fuel flow through the fuel line into the carb is an unobstructed, steady, thick stream the engine can run out of fuel, especially at higher speeds...
Even if it doesn't run dry, the fuel level in the bowl can get too low and cause all sorts of weird symptoms.
