hi my motomarina sebring allways stalls after the engine is reved hight then put back down to low throtle. I have no idea wat to do. dose any one no ive cleaned the carb also
thanks
thanks
if the engine bogs or dies when the throttle is opened up, there are numerous causes for this.
plugged up air box, plugged up filter, choke stuck closed, dirty carb, stuck reed valve (if your bike has reed valves), low compression, plugged exhaust port, plugged exhaust, incorrect ignition timing. clean and repair as neccesary.
_________________
donp
Dons Ride-Ons
used bikes
1695 Sunview dr
Lyndhurst, Ohio 44124
