PA50 CARB
Hey there peeps, i was wonderin if anybody has a tech sheet/ part list/ explodded tech drawing of 83 Honda PA50, cuz we,though experienced, cant figure out what wrong with it after having it out for the fifth time
thanks a bunch to anyone,
Fin
email if u want at Finster57@epix.net
Re: PA50 CARB
we want the carbs tech sheet etc.
Re: PA50 CARB
what are the symptoms?
there's an exploded view .. a few cleaning, inspection tips in the Honda PA50 Shop Manual (PDF) on THIS page
Re: PA50 CARB
Give us the dope.
Does it run?
Does it run but not idle?
Does it idle but not run fast?
Re: PA50 CARB
Don Pflueger /
did you assemble the fuel bowl in the correct direction? it fits on two ways but only one is correct. cleaning is simple. tear it apart, run wire thru every hole in the carb body and all its parts, follow up with blasts of carb cleaner, reassemble.
Re: PA50 CARB
heres the dope, as one of yous adequectly put it, the ped will run beautifully from half throttle to full throttle but below half it runs horribly and dies. the fuel bowl is on right it (thye carb) been cleaned three times and looks like new, all the holes are very clear in everything that we can see and we've blasted stuff through it. we dont know if a small brass gas/air mixing tube is in right and we dont know what it should look like so if u have any clues/ suggestions as to how it sholud go tell me it all
thanx
fin
Re: PA50 CARB
Don Pflueger /
if the bowl is installed backwards, the float binds. this can explain your idle issue if the engine is flooding. you should also look for an air leak at the intake manifold, cylinder base gasket, and crank seals. www.partsfish.com should have an exploded view of your carb.
Re: PA50 CARB
The little mixing tube (emulsion tube) goes in only one way.. One end of the tube opens up to a bigger hole.. this end of the tube is also slightly smaller in diameter.. this end goes upwards. (The other, bottom end has the cross-drilled hole near the end of the tube.)
Once the tube is seated up in the emulsion chamber, it's tip extends slightly into and can be seen in the carb's throat. The main jet seats it and holds the tube up in there.
Since you've got low speed trouble, something related to low speed running may be clogged.
There is an idle jet pressed into the carb body. It is under the flat-headed cover screw (below the idle speed screw). This jet's bore hole is very tiny. Find the thinnest strand of straight wire you can.. and poke it into the jet's bore to assure it's open. A single strand of throttle cable may be small enough. The bore hole is so small and deep in there that you may have trouble seeing it or getting the wire into it.
Although this jet is an "idle" jet, it does contribute fuel to part throttle operation untill about half throtle.. it and the whole idle pathway must be clean and clear.
Re: PA50 CARB
I want to thank you guys for your help on the pa50 carb,Iam proud to announce she is up and running.
I could not have done it with out you.
Finn
Re: PA50 CARB
what was wrong with it?
