Re: Broken, Old, Piaggio Vespa
Julia /
I think that it has to do with the HT Coil. I believe that that is where the points are located, within that. What I meant by not turning on all the way was that the engine doesn't seem to be turning over. If you still dont get what I mean, then I'll try to explain it further, but in the meantime do you have any suggestions with what to do with the HT Coil and or the Pointers. Thanks alot
